QUOTE (nc211 @ Oct 20 2008, 10:30 AM)
The GX certianly rides better then the 4runner, quite a bit better actually. But, I'm not so sure the difference between the two setups warrants the cost difference between the two with regards to servicing the suspension. On a "normal" set up, it's a $100 strut and two bolts. On the air suspension, you're dealing with stuff Gman references to, like the height sensors, and then it's air bags, pumps, hoses, etc... I think the answer lies in the question of "is the ride worth it to you?" Many say yes, and I can see why. But many also say no, and I too can see why. I know on the LS series, we tell folks looking at older models to avoid the air suspension setup, as it costs nearly $1,500 per wheel to replace. I'm sure the GX is designed to take a lot more abuse then the LS, but if buying used, I'd be weary of that. The interior difference though between the GX and 4runner is no comparision. The GX is soooo nice! 4runner is nice too, but nowhere near the GX.
Air suspension can very expensive to replace. But I have had several Lexus service technicians and members of this board tell me that the newer design is much more reliable and will last a very long time, much longer than the setup on the old LS400s.
I would not hesitate to buy a GX or any other Lexus model equipped with the newer air suspension design.
