Help - Search - Members - Calendar
Full Version: Vsc & Engine Lite "07 Rx350
Lexus Owners Club (USA & Canada) > Lexus Owners Club > Lexus RX300 / Lexus RX330 / Lexus RX350 Forums > 07 - 09 Lexus RX350
Nodgob
VSC Light & engine lite came on for no apparent reason. Live in Raleigh, NC. Is this an immediate safety issue? Is this a common problem? Is this a warranty issue for 16,500 miles? Otherwise is this only correctable at the dealer?
SouthamptonLexus
QUOTE(Nodgob @ Jul 5 2008, 12:33 PM) *
Take it in. They will check the code and go from there. Evap or a/f sensor codes are the most common. Since you have 16.5 k on it. It will be covered under warranty.
Lexus_RX350
RX350 2007, VSC and Engine lights, codes: P0138 and P2195, Bank1 sensor 1 and sensor 2 failure.
Schedule to Lexus shop tomorrow (1/7/09). As per my mechanic these are under warranty.
Lexus_RX350
VSC and Engine llight on, still under warranty. No charge.
rlpiv
QUOTE (Lexus_RX350 @ Jan 8 2009, 09:23 AM) *
'07 Rx350: I've had the same problem ... the first time I had my Lexus dealer tell me to tighten the gas cap ... I did and the problem was resolve, even though it takes a few tanks for the light(s) to go out. Since I don't like to 'overtighten' anything, it's happened a couple of times since and retightening the gas cap and 'enduring' a few tanks of gas ... and the LIGHTS GO OUT.
Ron Pierson
Dick_Lake_Tahoe_NV
When the "Check Engine" light comes on, it often causes panic--"Ohmygod my engine is about to quit--or something worse". It's not that the Engine is going to quit, it's some malfuntion in the emission control system. If the problem happens only once (say a spark-plug missfires), then after about 3-cycles of starting and driving the car, the light will go out automatically, as it did when the gas-cap was tightened correctly.
So before you panic, just drive the car for a little while and see if the light goes out--if not then get it diagnosed. Nothing critical will happen in the meantime.
Benny1997
I had a similar issue with my 2007 RX350 with 59,900 miles on it. THe Check Engine light and the VSC light. The Lexus dealer said it had code P2195 and I needed to replace an A/F sensor. Since I was above 50,000 miles, he said it was not covered by warranty and would cost around $500 to replace. He said that as a goodwill gesture they'd split the cost with me. When I picked it up I was charged $250 for labor, plus about $37 for Hazd./Shop charges. They also had me sign a 2nd invoice so they could recoup about $220 from Lexus.
As I look back at it, I'm wondering if the charges were appropriate.
Georgean78
QUOTE (Benny1997 @ Mar 10 2009, 08:06 PM) *
I literally just had this happen to me and why I became a mbr of the site. My 2007 RX350 has a little under 30,000 miles on it and all of sudden the VSC and check engine light came on. I scheduled service and then did a search online.
I kid you not, I opened the gas cap and then put it back on until I heard a couple clicks,,,,the lights went right off. So check this first and thank for all the good info!
dpatk4
QUOTE (rlpiv @ Jan 15 2009, 03:20 PM) *
Ron Pierson
I have a 07 RX 350 went to get gas forgotten to tighten the cap and the lites came on is it ok to drive it like this?
Pam
jgr7
Yes, just tighten the gas cap and drive it, the light should go out after a short period of time.
Jeff
RMB350
Did you recently have an oil change or any other service work done?? On my Highlander, when the air box lid is removed to check the filter, a vacuum hose pulls out. Within a day, the lights come on. Plug the hose back in and the lights will go off within a few days.
I make sure that I check this hose every time it's serviced for anything..
It's worth a shot to check it out. Just peek around the air box with a flashlight and look for a loose hose.
I'll bet you find one..
dpatk4
QUOTE (jgr7 @ Aug 24 2009, 08:00 PM) *
Jeff
I am afraid to drive with it like this my appointment is for tomorrow ,it better not be a lot of money, it only has 54000 that is nothing.Would not buy another Lexus! And what is a short period of time?
dpatk4
QUOTE (RMB350 @ Aug 25 2009, 08:35 AM) *
I took my lexus where I bought it to get a oil change and they stripped my threads on my oil pan,I had to replace the oil pan and they did a oil change then, that was July it was about 5to6weeks ago .Did your car run ok with the lites on?
dpatk4
Jeff
I drove it today and the lites went out for about 25 mins and came back on taking it in tomorrow sick of this problem!
dpatk4
QUOTE (dpatk4 @ Aug 27 2009, 03:59 PM) *
Jeff
I took it in and they said it was the coil it was driving BAD! They paid half of the bill I thought that was good. If anybody has had this problem please let me know your story.And what is a coil?
dpatk4
QUOTE (dpatk4 @ Aug 27 2009, 01:45 PM) *
Jeff
Took it in today the coil went bad in it.Replaced it and I had to pay half . It really was driving bad when I took it in .What does a coil do?
Chris Parker
QUOTE (dpatk4 @ Aug 28 2009, 07:07 PM) *
I thought these cars had coil on plugs (COPs) for better reliability. Do you know what cylinder's coil they changed? The coil is a capacitor-like thing which delivers a burst of charge to the spark plug each time it is signaled by the ECU to spark. Older cars had coil packs, but I thought RX330/RX350 had a separate coil built right into the spark plug.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
