When my headlights are off, I get no warning light. The minute I turn my headlights on, I get the "Tail light failure" warning on the instrument panel. All my tail lights are illuminated.
I have no idea if I have OEM bulbs or not, just had 2 replaced by the local Toyota dealer (took 2 trips ... grrr) .. you'd think they'd at least look at them after replacing the bulb ... sigh.
So, is the recommended procedure the following:
- double check all lamps .. including one in the back window
- replace all bulbs with OEM bulbs
- check for corrosion and clean sockets
- check for correct voltage (12.5 amps)? Can I use a volt-meter for that?
- check wiring box in truck hinge (if option for my year)
- check alternator
Other ideas?
Even with the troubles so far, I *love* my "new" car.
Thanks so much guys!
