Just did the 1000 mile break-in oil change on my ES350. Very easy for the DIY'er
Parts: Toyota 04152-YZZA1 Filter kit
Toyota 90430-12031 drain bolt gasket
7 quarts 5w30 SL/SM oil ( takes 6.4 qts with filter change)
Tools: 14MM box end wrench
3/8 ratchet with 4" extension
65-67MM oil filter wrench
1-wooden toothpick (to remove o-rings DO NOT use a metal tool)
Floor Jack
Oil catch pan
6" piece of old 1/2" garden hose
1. Raise car about 5-6 inches find oil drain plug on oil pan and remove w/14MM wrench draining oil into catch pan.
2. Reinstall oil drain plug with new gasket (be sure to remove old gasket as it will stick to the pan drain hole, tighten plug.
3. At front RH of car underneath you will see a round aluminum oil filter housing. It is gray and has an indent for the 3/8 drive extension. Insert extension into housing and remove oil housing cap. (a small amount of oil will come out).
4. If the small black o-ring comes off with the cap put it back on as it will seal the draiining of the filter
5. Take small plastic drain insert from filter kit and insert the long end into the piece of garden hose.
6. Insert the pronged end of the plastic drain insert into the filter housing making sure to direct the hose into catch pan. The oil filter will now drain.
7. Remove plastic drian insert when filter is drained. (twist and pull out)
8. Using 65MM oil filter wrench unscrew filter housing and remove. Remove used filter element.
9. Wipe clean and replace small o-ring with new small o-ring and reinstall cap on housing (be sure to oil new o-ring so it seals correctly). Tighten cap with 3/8 ratchet extension.
10. Remove large o-ring from filter housing and re-install new large o-ring from filter kit ( be sure to oil new o-ring). NOTE: use the wood toothpick to remove the o-rings because if you scratch the aluminum housing it will leak.
11. Place new filter element in housing and push all the way in.
12. Wipe housing cavity (on the engine) clean and re-install filter housing by hand. Be sure not to dislodge o-ring. Turn in tight all the way by hand and apply light force with filter wrench (remember you are not tightening another 1/4 turn like a conventional filter) Be careful not to cross thread housing into cavity.
13. Add 6.4 quarts of 5w30 oil
14. Wipe everything clean
15. Start car and allow to run for 5 minutes. Check drain bolt & filter housing for leaks.
16. Re-set maintenance reminder.
17. Shut car off, wait a few minutes and check oil level.
Note: If you rotate your tires every 5000 miles like I do the torque spec for the lug nuts is 76ft lbs.
