lexinva
Feb 26 2008, 10:55 AM
I recently bought a 98 LS400, with a beautiful gray exterior unfortunately marred with a painted silver & black (factory?) Lexus pinstripe.
The rest of the paint is in great condition for a 10 yr old car, but the pinstripe shows its age. The stripe seems so thin, I'm wondering if it can just be rubbed off with a chemical stripper of some sort. Has anyone had any experience with this? What did you use? Rubbing compound? Wet sandpaper? Magic Eraser?
jcrome04
Feb 27 2008, 12:51 AM
I know some companies make a pinstrip remover wheel type of thing you stick in a drill but that might be for vinyl ones only... I've never used one before..
raymsixsix
Feb 27 2008, 08:00 AM
QUOTE(lexinva @ Feb 26 2008, 11:55 AM)
Personally, I've not done this, but this guy has some great turtorials and apparently knows what he's doing.
http://www.lexls.com/tutorials/body/pinstripes.html
SW03ES
Feb 27 2008, 09:15 AM
Honestly? I would take the car to a professional for this. They will pick a chemical cleaner that will dissolve the stripe without damaging the paint and it will be much safer than you trying different things.
NEVER use a magic eraser on the paint! they are very abrasive.
lexinva
Feb 27 2008, 10:55 AM
Thanks for the replies. Wow- the "lexls" site is a great resource! Thanks for the tip. I've tried Easy-Off on painted letters on my fiberglass sailboat with outstanding results, but it never occured to me to use it on a painted surface. I may just give it a test on the gas flap like he suggested. If that doesn't work I guess I'll start getting estimates....
SW03ES
Feb 27 2008, 11:48 AM
Boats have a gelcoat though, its a different paint surface...
raymsixsix
Feb 27 2008, 12:23 PM
QUOTE(lexinva @ Feb 27 2008, 11:55 AM)
Your welcome...Yes, lexls.com has a lot of good info for the DIY. Good luck and let us know what you ended up doing
lexinva
Feb 27 2008, 03:58 PM
Has anyone else tried the "easy-off" method? I admit it's risky but I may give it a shot. There's no way I'd chance it if I had a dark paint color, but I think I'd be okay with silver. Will let you know what happens........
dair805
Jul 14 2009, 12:30 AM
Please send me some pictures of the area you want to remove. I have some experience on doing this. I would be a lot of help if I had some pics of your car (so I can see the problem) Thanks.
smooth1
Jul 22 2009, 03:30 PM
I have used the easy off method. In fact I have a tutorial in the IS forums also. It works great, and it doesn't hurt the paint at all. You will need to rewax the car afterwards though as it removes all waxes also.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
