Help - Search - Members - Calendar
Full Version: Replacing Factory Radio
Lexus Owners Club (USA & Canada) > Lexus Owners Club > Lexus SC300 / Lexus SC400 / Lexus SC430 Forums > 01 - 08 Lexus SC430
Chuck Ballew
The CD player in my Premium car stereo is broken. Has anyone replaced this with anything other than a new factory radio.
Things I would be interested in:
* a slide in slot for my IPod
* HD radio
I love my 430 and would like hearing from other owners!!
LSKOCH5
No responses back yet? Ugh, was hoping to get some ideas as my cd player jammed last week crybaby.gif , need to hear my cds, dealer said would need to replace w "rebuilt" at $615. And I need the driver's door speaker replaced as well - another $288. I believe I can get a great NEW (not rebuilt) stereo for this kind of money or a lot less, but was warned that I'd need to ensure the ohms and size were correct. Any specs on that? Thanks in advance for any advice. Oh, and did just unplug the battery overnight to try someone else's "accidental solution" to the same problem in another thread... we'll see if it by chance works.
Other than that, have LOVED my SC for two years now...
Chuck Ballew
QUOTE(LSKOCH5 @ Feb 7 2008, 08:46 PM) *
I had the speaker in the left and right door replaced for about 150 bucks total. I am looking for a radio too. Let me know what you come up with. Don't take your car to the dealer with radio problem. My local Master Car Sterero did the work.... Lexus wanted 800 bucks and said all speakers had to be replaced with secret ohm kit. LOL chair.gif chair.gif Thanks for the tires idea.
LSKOCH5
QUOTE(Chuck Ballew @ Feb 8 2008, 02:01 PM) *
No responses back yet? Ugh, was hoping to get some ideas as my cd player jammed last week :cries: , need to hear my cds, dealer said would need to replace w "rebuilt" at $615. And I need the driver's door speaker replaced as well - another $288. I believe I can get a great NEW (not rebuilt) stereo for this kind of money or a lot less, but was warned that I'd need to ensure the ohms and size were correct. Any specs on that? Thanks in advance for any advice. Oh, and did just unplug the battery overnight to try someone else's "accidental solution" to the same problem in another thread... we'll see if it by chance works.
I had the speaker in the left and right door replaced for about 150 bucks total. I am looking for a radio too. Let me know what you come up with. Don't take your car to the dealer with radio problem. My local Master Car Sterero did the work.... Lexus wanted 800 bucks and said all speakers had to be replaced with secret ohm kit. LOL :chairshot:chair.gif Thanks for the tires idea.
Thanks Chuck - haven't had time to look into stereo yet, what brand and size speakers did they use? I had purchased what another stereo place told me would be the correct speaker, yet after they took the door off even they said it wouldn't work, refunded me, and sent me to the dealer...You're welcome on the tires.
Goober
bump.
Realy could use some advice on this. hasn't anyone replaced the factory noise maker?
thanks
aquanuke
Ive seen a few done, should cause no problem to install an aftermarket unit. Obviously you have quite a big hole to fill though.
Chuck B
QUOTE(aquanuke @ May 22 2008, 06:28 PM) *
Where did you get that done. .t looks great. Where can I get mine done as well.
aquanuke
QUOTE(Chuck B @ Jun 4 2008, 07:23 AM) *
oh its not mine, im not big into ice anymore love the sound of my v8. Ive done ice installs and carputer installs in the past though. I have had the ml system out when I installed my dvd changer and TV. Its pretty straightfwd to rip out if your so inclined.
lazyjones
Don't let Lexus screw you. There is no "secret ohm" kit. All the speakers in the car are 8 ohms, except for the sub, which is 16 ohm. I just recently replaced all the speakers in my 2002 sc430, and the sound sounds 100% better than their "premium, Mark Levinson" system. I kept the factory head unit, as well as the factory ML amp to run the door speakers and rear speakers. Added an Alpine amp to power my new sub. You can find way better 8 ohm speakers than what is being used in the car. I did very little modifications to make the new speakers fit. In fact, the only modification I did, was changed the door woofers (which are 6 x 9) to 6.5" pioneer woofers. I had to use a little MDF to make the speakers fit. Was very simple. I changed out the rear speakers, and they fit fine. Changed out the sub, and it fit fine...(although, I wish I could have gone with a bigger sub. Only an 8" sub would replace the old one).
tame_junglecat
QUOTE (lazyjones @ Jun 19 2008, 11:57 AM) *
What kind of speakers did you exactly replace them with? I've yet to find an 8 Ohm car speaker. A 'home stereo' speaker isn't geared for this sort of application-- sonicly, or long term. I just broke down and purchased the ML 6X9 for the door as I blew the minimally rated 20W speaker. Do some searching on the web. I found one for $120. Anyway, my gripe is that playing music w/the top down is almost a joke if you're on the highway. Even replacing the sub becomes a big deal, as you're limited to where it can go-- plan on building a custom box in the back seat (as it's not very good for much else). You'll be better off placing it (them) here, than placing them in the trunk. It will sound better, and you will appreciate keeping the space available in the trunk should you need it. FYI, the existing sub cut out is far too shallow and small to replace it with anything-- even the shallow subs will not work, plus it will sound like garbage trying to play through the foam and leather seatback.
Unfortunately there's no real easy (or cheap) way to beef up the sound (or volume). ANY upgrades require a major overhaul, and you loose the asthetics of the car. Now, how about an aftermarket 8-Trak tape player to match the cassette deck?!!? LOL. Good Luck.
mschlee
Has anybody successfully replaced a factory radio and adapted the steering wheel remote ?
Thanks for any advice
Greetings from Germany
M.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2009 Invision Power Services, Inc.
