muddober
Jan 24 2008, 06:45 PM
oil from the new k&n air filter can coat the mass air sensor atracting dirt and fuzzies causing it to give fals readings. it caused the computer to give me vaccume leak warrnings witch also affected the the abs computer.
blake918
Jan 24 2008, 10:41 PM
You must be putting too much oil on your filter because I've been using a K&N filter in my Lexus for a long time now with no problems whatsoever.
SKperformance
Jan 24 2008, 10:53 PM
agreed , improper oiling of the filter from applying too much and not letting it drip dry as indicated in the instructions is the problem.
Lexus300Stock
Jan 30 2008, 07:40 AM
^^^ my guess.. u didnt oil ur filter right.. and u need to clean ur MAF anywayz... spray mass air cleaner on the lil leads like 5 times.. then stick it back in...
mburnickas
Feb 1 2008, 05:06 AM
QUOTE(Lexus300Stock @ Jan 30 2008, 08:40 AM)
K&N sucks..Any filter you need to oil is poor. Why? I have stated for years it is a fine line and 99% of people do not do it correctly. Over oil will kill sensors (been there done that). Under oil, been there and you WILL have high (very high) wear numbers as shown per UOA. Plus unless you are racing the car, the increase in HP is marketing BS. So unless you test your oil, you have no idea on how it is working.
jcrome04
Feb 2 2008, 07:17 PM
I've never had a K&N filter cause any harm to me. Just be careful when you're cleaning and re-oiling.
As for the power increase.. some cars it's noticeable, others it's mostly just noise, so stock or K&N, either way to all their own I say!
mburnickas
Feb 5 2008, 10:43 AM
QUOTE(jcrome04 @ Feb 2 2008, 08:17 PM)
Pull a UOA then tell me that.
Lexusfreak
Feb 5 2008, 01:51 PM
I switched from K & N to Amsoil Ea synthetic air filter....all you do is remove it, vacuum it out & re-install.....no oiling.
mburnickas
Feb 6 2008, 05:50 AM
QUOTE(Lexusfreak @ Feb 5 2008, 02:51 PM)
Bingo and filter WAY better per cap and eff ratings. It looks like Amsoil is got the market on oil filters and air filters currently.
Lexusfreak
Feb 8 2008, 02:25 PM
QUOTE(mburnickas @ Feb 6 2008, 06:50 AM)
:cheers:
Funny thing.....my previous 2 vehicles (including my 2001 Lexus ES) had this air filter......I went to look up the one for my 2005 ES & they don't make it for the 2002 - 2005 ES models......figures!
Lucio@KNFilters
Mar 13 2008, 12:12 PM
K&N has never been provided any evidence of a MAF sensor being fouled by filter oil regardless of how much oil was used on the filter. We have tested over 100 MAF sensors allegedly harmed by filter oil and have yet to find any trace of filter oil on the sensors. What we did find was that 60% of the sensors in question were performing perfectly with no defect and had in fact been misdiagnosed. 18% of the sensors had complete electronic failures in no way due to contamination while 22% were out of tolerance. Again not a single one had a trace of filter oil on it. For more information on this issue and K&N’s consumer protection pledge go to
http://knfilters.com/MAF/MAFTestresults.htm. K&N is proud to have complete quality control by doing our testing, development and manufacturing in the USA. Not only have we sold in excess of 20 million air filters worldwide but we continue to be used by many top racing teams including the winners of the 2007 Baja 1000 and Baja 500 (and the 2008 Daytona 500).
mburnickas
Mar 13 2008, 02:23 PM
Sorry but I messed up sensors (air temp) in diesel engine (10X the air flow) with these oil glazed filters. Not worth the issues. Plus I know FORD will not honor any warranty issues when these types of filters (wet oil glazed cotton etc) installed. Warning labels all over; take that for face value.
In fact, I would use an Amsoil EaA air filter over any oil glazed filters. Cheaper, better eff/cap, no oiling ($$$), no wasting/cleaning ($$$$) etc. Heck I would take a paper over K&N.
I also just had problems with my K&N in my motorcycle. Trashed it and all better and that was at the dealership that has seen these issues before.
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
