Luxury Motor Works makes/sells the LuxLink module....
Luxury Motor WorksHowever, it won't solve your problem. The module just tells the car when to make the top go down. If the car won't let the top go down, the module can't make the top go down either. For example. If the retractable tonneau cover in the trunk is not extended in place, the car won't let the top go down, and the LuxLink module can't override this...it's essentially just holding the button down for you.
However, if there's some interlock that's not letting the car put the top down (like the tonneau cover), the light on the top switch should blink, telling you "Hey, something's not right". If you press and hold the button, and the red light on the switch is on solid but the top isn't moving, it's time to head to the dealer. If the light's blinking, it's probably either the tonneau cover not seated properly in the trunk (make sure BOTH sides are slid all the way in place) or the button in the glove box is in "valet" mode...which disables both the retractable top and the button-on-the-dash trunk release.
Good luck and let us know the result.
