Worked nicely for me. Thanks!
QUOTE (pfrass @ Oct 18 2007, 11:16 AM)
Clearly referring to a different vehicle. My tripometer reset is on the touch-screen and holding it seems no different from simply touching it for short period of time.
Turn Off Seat Belt Buzzers:
(a) Driver and front passenger side seat belt buzzers
(1) Turn the ignition switch to the ON position.
(2) Press the ODO/TRIP switch until the odometer displays "ODO".
(3) Turn the ignition switch off.
(4) Turn the ignition switch to the ON position.
(5) Press the ODO/TRIP switch immediately (within 6 seconds) and hold it down for 10 seconds or more.
(6) Continue holding down the ODO/TRIP switch and fasten the driver side seat belt.
(7) Check that the odometer displays either "b-on" or "b-oFF".
(8) Press the ODO/TRIP switch to change the display to "b-oFF".
(9) Turn the ignition switch off.
(10)Turn the ignition switch to the ON position.
(11)Check that no buzzer sounds.
Front passenger side seat belt buzzer
(5) Sit in the front passenger seat. Press the ODO/TRIP switch immediately (within 6 seconds) and hold it down for 10 seconds or more.
(6) Sit in the front passenger seat. Continue holding down the ODO/TRIP switch and fasten the front passenger side seat belt.
