QUOTE(davisnetworks @ Jun 9 2007, 06:42 PM) [snapback]245144[/snapback]
I am about to purchase a LX-450, but it doesn't have the differential locking system on it. I was told that i could be installed becuase it was pre-wired and I only needed the switch. I went to our local lexus dealer and they have the switch avaliable for $45ish. Can someone please tell me it I can add it on to it and get the locking system and if not, could it be possible at all. Thanks!
WHOA!
no. this is simply NOT true.
sure, the switch might be $45...for the record, I don't know how much the swtich is...but there's MUCH more to the locking differentials than just the switch.
either someone was very misinformed or lied to you BIG time.
it is possible to get OEM lockers installed, but it's a bunch of work and quite expensive.
most who want to go with diff locks (and want the best (aside from OEM)) go with ARB air lockers. You'll be looking at anywhere between $2500 and $3000 to get ARBs installed (that's parts and labor combined).
If you can find a donor 1994 - 1997 Land Cruiser or 96/97 LX 450 axles with locking diffs installed AND the associated wiring harness, you might be able to get it done for a bit less...but not much less than the ARBs.
If you want lockers, but don't want to spend the extra cash, find one with OEM lockers.
I know that some come up from time to time on the classified section of the www.ih8mud.com forum. you might look there.
good luck in your search.
