Help - Search - Members - Calendar
Full Version: Does Anybody Have A Anti-sway Bar Installed?
Lexus Owners Club (USA & Canada) > Lexus Owners Club > Lexus ES250 / ES300 / ES330 / ES350 Forums > 92-06 ES250/300/330
andrecat112
does anybody have a anti-sway bar installed on their car? if so which one?
i found this one from ADDCO:ADDCO rear anti-sway bar
it says its a "3/4 inch diameter bar" is that the proper size for my car?
i didnt think you could improve the suspension of a es300 w/o having to dish out some $$$ for coilovers (which i dont have the money for). but i replaced the front struts with OEM not too long ago, and for the rear settled for monroe shocks (yes i know, i have different brands for the front and rear blushing.gif but the OEM for the rear are expensive crybaby.gif )
Toysrme
IPB Image
Whiteline rear sway bar, poly mounts & end-links for me.
ADDCO is a love/hate thing. Some people really like them. Some don't.
Especially the front sway bar they sell for then gen4 Camry platform. Toyota undersized the front sway bar, hence both Whiteline & ADDCO make a FSB to balance it back out. About half the people that buy the ADDCO FSB sell it. The good news is they're cheap used LoL!
The top end monroe struts are compairable to the OEM KYB-GR2's. The mid grade are what compraiable to what comes on a Caddy.
If you're looking for sporty. The first thing you do is ditch the rear sway bar, followed by the front. (on the gen4's i.e. 97-01
From there, struts springs & mounts, or full blown coilovers.
Skip strut tower braces. They don't do anything handling wise and cause hood & engine clearance problems.
andrecat112
QUOTE(Toysrme @ Jul 6 2006, 11:32 AM) [snapback]198783[/snapback]
you say the gen4 Camry platform has a front sway bar, do the gen4 es300 platform have front sway bars also?
QUOTE
(i dont know how your suspension is setup) but why did you consider getting a Whiteline rear sway bar? do you feel any improvements having it?
(correct me if i am wrong) is the purpose of a rear sway bar to control the rear end as you manuever through a turn?
Toysrme
QUOTE
Yes, you basically have a gen 4 Camry, just with better parts, build quality, looks nicer, far better interior/body etc. And it's built in japan only smile.gif I.E. Toyota Windom woo woot!
QUOTE
Without going into how the physics work out. The stronger the bar, the less grip that end of the car has. (Hence, the more lateral traction the opposite end of the car has). and vice-versa.
Because in almost every FWD car, you are understeering (loosing traction on the front wheels when applying poewr during cornering, or just all the time for almost all factory cars.), you want MORE front traction.
A larger rear sway bar will let the back end slide more, while giving the front end more traction. Which is exactly what you want.
In the process the body roll is much, much less, while the steering, and tracking usually sharpen somewhat.
In the case of the 97-01's, because the front bar is still somewhat too small, you can upgrade those as well to help balance the car.
Most manufactureres set cars up to understeer. Loose grip in the front wheels. It's the bad way to go around a corner fast, but if you do loose it, atleast the nose of the car will continue to go in the same direction. (better for newbs) With most rear sway bar upgrades on a FWD car. You will still understeer around most corners hustling, but you can induce oversteer (the back end sliding out, or wanting to spin out) easily enough. A quick flip the the wheel & mild counter-steer, or a flip of the wheel & a shot of gas pedal is all it takes. In any event, instead of just sliding out of a corner, a RSB will take out some body roll, and help neutralize the handling.
Without doing an major money / suspension changes. A rear sway bar is *the* first thing to upgrade on any FWD car. It's the biggest change for the money, makes a big change period, and even if you have the money for big mods, it's very high on the mod list of "I have to have that period".
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please click here.
Invision Power Board © 2001-2010 Invision Power Services, Inc.
