i8hotdogs
Jun 10 2004, 05:32 AM
Hello All - I was testing the vehicle height control the other day and I would like to know if this is normal. The vehicle will drop or raise properly, but what good is this feature if the height returns to the normal height as soon as the car starts moving? I first thought that the height control will only stay at the designated height until you reach a certain speed, but it was not the case. When I lowered the vehicle and drove 5mph, the truck would still return to the normal hight. Is this normal? If so, what is the point of the adjustment feature?
Thanks
jrwright
Jun 10 2004, 02:19 PM
Nope, that doesn't sound normal. I think the speed threshold is around 15 MPH.
jarcara
Jun 12 2004, 06:25 PM
the manual indicates it should return at 19+ MPH. have it looked at on your next dealer visit.
haplain
Jun 14 2004, 12:56 AM
i wish there was some way that you could make it ride in high or low (pref low) while going over 19+ MPH does anyone know of any way to do this
Traveler
Jun 15 2004, 07:12 PM
The system should stay at low or high until you reach a certain speed. The low speed cut-off is very low; the high is a little above 15.
What you describe (going immediately to NORMAL) can be caused by a software(?) error which gives an incorrect reading until the system is reset with a truck restart -- sometimes this does not help, either.
Of course, your truck could just be returning to NORMAL.
Lexus corporate says you can not keep the truck in anything but NORMAL above the set speeds. However....
You could add a power on/off switch to the power line to the control module for the height adjustment. The manual has the module's schematic.
Does this work? I don't know. It should, but I have not tried it yet on mine.
Remember that driving at higher speeds with the vehicle on LOW or HIGH does have its own inherent risks, so changing the system may not be a good idea.
The system should allow for more direct control, though. A heavier load than 700 pounds over the rear axil overrides the ride control and the truck squats. That is normal, but unless you lower the front, you headlights point too high. Of course, you can't lower the front above 15.
Oh well.
traveler
GRD
Jun 15 2004, 09:35 PM
| QUOTE (i8hotdogs @ Jun 10 2004, 05:32 AM) |
Thanks |
The low height control will never work while driving. It is used for getting in, loading, etc. As soon as the car is shifted, the vehicle will go to N.
The high option will lower to N as soon as you hit 19MPH.
George
jpinkert
Jun 29 2004, 01:11 PM
The height control is pretty sophisticated. As has been said, the -low- mode is only for loading/unloading. My experiences have it raising to -normal- at anything faster than a crawl. It also seems that the shock dampening goes really soft when you go into -low-. I wouldn't recommend trying to fool the system to drive in -low- for any reason. I think it would be unsafe, floaty, and you'd risk hitting your bump stops.
Based on the manual, there's also an extra-high mode that it goes into when you're stuck offroad. I guess it assumes that you're high-centered and need a little extra clearance to get moving.
r3run33
Aug 6 2004, 03:56 AM
hey christo has and override in his 470 but his is done for the high position. send him an email on how he did it.
haplain
Aug 8 2004, 04:11 PM
how would i go about getting a hold of christo i cant seem to find him
This is a "lo-fi" version of our main content. To view the full version with more information, formatting and images, please
click here.
