Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
> Car Won't Click, Battery Completely Dead After Trying To Start Ls4
JTom
post Nov 3 2009, 07:26 PM
Post #1
New Club Member
Group: Regular Member
Car Model:ES400
Update: Disregard title, it will click. My female positive terminal is completely corroded on a 1992 LS400 so much so that also me being new to working on my car grinded into the positive pole of my male battery. Also if it's not in the right position it won't turn on or get power. Right now though I can turn on my brights, radio, and A/C and still just get one click.
Go to the top of the page
+Quote Post
JTom
post Nov 3 2009, 07:38 PM
Post #2
New Club Member
Car Model:ES400
I'm guessing very likely I activated the anti-theft. At least I hope that's just that. Any thoughts on how to disable?
+Quote Post
curiousB
post Nov 3 2009, 08:16 PM
Post #3
Advanced Club Member
Car Model:2004 LS430
QUOTE (JTom @ Nov 3 2009, 08:38 PM) *
Clean up the battery connectors with a wire brush and be sure bolt torqued down well. Replace rusty bolts with new. Loose connections won't allow the 200-300 AMPs a starter motor will draw. Other things working but they are a very light draw on battery compared to starter motor.
+Quote Post
JTom
post Nov 3 2009, 08:23 PM
Post #4
New Club Member
Car Model:ES400
QUOTE (curiousB @ Nov 3 2009, 08:16 PM) *
Yeah, the positive female terminal is completely corroded on the battery. Might have to be replaced but that's a hell of a lot better than the starter if it is it! Thanks man for the tips will get some new bolts too.
+Quote Post
laney94
post Nov 4 2009, 03:22 PM
Post #5
New Club Member
Car Model:LS400
QUOTE (JTom @ Nov 3 2009, 09:23 PM) *
On my 94ls, to disable the security feature, lock and unlock the passenger door with the key. Sears just put in a new battery for me and they spent 20 minutes trying to start the car before they asked me about the lock out feature.
+Quote Post
VBdenny
post Nov 4 2009, 04:10 PM
Post #6
Guru Member
Car Model:LS 400 (1990) ES330 (2004)
How'd you find an ES400?
+Quote Post
laney94
post Nov 4 2009, 04:30 PM
Post #7
New Club Member
Car Model:LS400
QUOTE (VBdenny @ Nov 4 2009, 05:10 PM) *
Hah - good catch VBdenny! I believe that'd be a typo.
+Quote Post
VBdenny
post Nov 4 2009, 05:45 PM
Post #8
Guru Member
So which part is wrong? The "E" or the "400" lol. my guess is the "E."
As far as the starting issue goes, these LS 400's need a lot of juice to start. To jump them you need to wait 10 minutes after connecting the cables. Ask the attendants at the Newark Airport. Check the battary cafeful, very important.
+Quote Post
etex
post Nov 5 2009, 10:52 AM
Post #9
Club Member
Car Model:1997 and 1998 LS400
I'm having trouble distinguishing the sexual orientation of an automotive battery. Which post is male, and which is female??
+Quote Post
laney94
post Nov 5 2009, 01:09 PM
Post #10
New Club Member
Car Model:LS400
QUOTE (etex @ Nov 5 2009, 11:52 AM) *
Lordy, I'm confused too. His is a male battery, so that explains a lot.
+Quote Post
landar
post Nov 5 2009, 05:18 PM
Post #11
Car Model:1998 LS400, 98 Chrysler Town&Country, 65 Mustang Conv.
Jtom...one click *usually* means one of two things: a bad starter relay OR corroded starter solenoid contacts (in the starter).
Corroded/bad connections at the battery usually produce a machine gun clickety-clickety for as long as you hold the key in the start position and not just one single click.
A theft deterrent cause would usually result in no response at all(from a key turn) but perhaps there is some small anti-theft relay clicking somewhere. I am not familiar enough with anti-theft to say for sure.
If it is a fairly loud metallic click and appears to be coming from the back of the engine compartment, you might be looking at a starter rebuild/replace.
+Quote Post
VBdenny
post Nov 5 2009, 05:22 PM
Post #12
Guru Member
Red (+) & Black (-)
Male - w/posts
Female - side mount
+Quote Post
fblonk
post Nov 5 2009, 07:16 PM
Post #13
Club Member
Car Model:1998 LS 400 (2)
If you are interested the positive terminal is replacable...
Toyota part # 90982-05054
Good Luck,
Fblonk
+Quote Post
eatingupblacktop
post Nov 5 2009, 08:19 PM
Post #14
Motorhead lite
Car Model:All stock all original 91 ls400
Location:Either On The Highway To Hell or The Stairway To Heaven - depends what on time of day it is!
How to identify a female post:
How to identify a male post:
+Quote Post
RSS Lo-Fi Version Time is now: 21st November 2009 - 07:55 PM
