Jul 18 2009, 07:45 PM
Post
#1
Club Member ![]() ![]() Group: Regular Member Posts: 75 Joined: 8-May 09 Member No.: 93,730 Car Model:es300 Location:NJ |
2002 ES300, 154,000 miles (all highway)
I got this CEL - PO430 - Catalyst efficiency below treshhold ( Bank 2 ). (i've been getting 25-27 mpgs, calculated at the pump, not sure if this is important) I ordered OBD II --> USB reader off ebay for 25$ shipped and installed this software: OBD 2007 software manual: http://rapidshare.com/files/257591733/OBD_...ogram_Guide.pdf ![]() I am trying to figure out why i Have PO430 and why it randomly appears/disappears. If this was a cat converter wouldnt i have CEL permanently? I took some screen shots, this is my first time running such extensive OBD diagnostics. Please take a look and comment if you have an idea about what might be going on here or what other tests i should do to troubleshoot this... (i must say the software is pretty cool and very user friendly, tons of cool features to play with) ![]() ![]() 610 rpm: ![]() 2200rpm: ![]() data snap shot (stored in the ECU) when the PO430 code came up for a first time, i do remember being on the highway and driving at 75mph when this happened: ![]() not sure what this is: ![]() O2 sensors while revving up 600->1400rpm:
rlx101 Check Engine Light Po430 2002 Es300. Obd Software Screen Shots. Jul 18 2009, 07:45 PM
rlx101 O2 sensors 1400-->600rpm:
2krpm sensors:
... Jul 18 2009, 07:45 PM
rlx101 fuel analysis at 2000 rpm: Jul 18 2009, 08:05 PM
George_Jetson It looks like they did a good job with the gui int... Jul 18 2009, 09:15 PM
rlx101 hi george,
i think its $80 for the software, ... Jul 18 2009, 09:54 PM
George_Jetson 7% is high, and if you notice at the higher rpm th... Jul 18 2009, 11:15 PM
rlx101 i understand that propane test should be done quic... Jul 19 2009, 07:53 AM
George_Jetson The air temp ,normally runs a little high, I would... Jul 19 2009, 12:17 PM
rlx101 what i dont understand is if i have a vacuum leak,... Jul 27 2009, 08:08 AM![]() ![]() |
Lo-Fi Version | Time is now: 9th February 2010 - 08:02 AM |
