Jun 18 2009, 01:03 PM
Post
#1
New Club Member ![]() Group: Regular Member Posts: 2 Joined: 18-June 09 Member No.: 96,485 Car Model:lexus gx470 Location:Pismo Beach, CA |
I recently took my 2004 GX470 (75k miles) in for routine maintenance. The shop tells me there is a pink califlower running down the radiator, indicating a leak. They recommend replacing the radiator with an after-market unit for an out-the-door cost of $583.
This shop is independent (toyota and lexus trained technicians, who formerly worked at Toyota and Lexus dealers). I stopped going to a distant dealer after my warranty expired. Have Lexus (or GX470s in particular) had radiator leak problems? I read one other forum for Lexus owners stating that some Canadian made radiators had manufacturing problems in the mid 2000s. Any experience out there with this? I am being soaked for $583? |
Jun 19 2009, 09:51 PM
Post
#2
New Club Member ![]() Group: Regular Member Posts: 8 Joined: 18-May 09 Member No.: 94,292 Car Model:2004 GX470 Location:Phila |
I recently took my 2004 GX470 (75k miles) in for routine maintenance. The shop tells me there is a pink califlower running down the radiator, indicating a leak. They recommend replacing the radiator with an after-market unit for an out-the-door cost of $583. This shop is independent (toyota and lexus trained technicians, who formerly worked at Toyota and Lexus dealers). I stopped going to a distant dealer after my warranty expired. Have Lexus (or GX470s in particular) had radiator leak problems? I read one other forum for Lexus owners stating that some Canadian made radiators had manufacturing problems in the mid 2000s. Any experience out there with this? I am being soaked for $583? My 04 had same radiator leak at 80k, replaced by dealer under warranty. As an example, GX radiator at AutoZone is $270-$300, eBay prices are $150-$250. Shops usually have their suppliers and get discounted prices. Replacing GX radiator is not that hard, there is plenty of clearance in the front. I would ask the shop how much the labor costs and go from there. |
Jun 20 2009, 09:44 PM
Post
#3
![]() Advanced Club Member ![]() ![]() ![]() Group: Regular Member Posts: 258 Joined: 20-November 05 From: houston Member No.: 21,708 Car Model:LS400- 1994 / GX470-2004 / LS460 - 2007 Location:HOUSTON |
You just need basic tools to do the replacement, at your home garage. Simple save labour cost
goto this website http://www.drivewire.com It only cost 275/- |
Jun 23 2009, 03:10 PM
Post
#4
New Club Member ![]() Group: Members Posts: 1 Joined: 7-November 08 Member No.: 82,644 Car Model:2006 LEXUS GX470 Location:CARSON, CA |
Just took my 06 GX in for 45k service and they found a leak in the radiator and replaced it under warranty. Not sure if it a common problem but may be.
Jun 25 2009, 12:00 AM
Post
#5
![]() LOC Moderator Group: Super Moderator Posts: 2,885 Joined: 21-June 04 From: Fresno,CA Member No.: 9,735 Car Model:2003 Sand Dollar Pearl Lexus GX470, 2006 Natural White Toyota 4Runner, 2009 Space Gray Metallic BMW 528i Location:Fresno, California |
This is interesting. Never noticed that radiator leaks were starting to become common on the GX. Luckily I never had a radiator leak (knock on wood) and I'm at 54k miles at the moment.
Jun 29 2009, 10:17 PM
Post
#6
New Club Member ![]() Group: Regular Member Posts: 3 Joined: 4-January 09 Member No.: 86,005 Car Model:GX 470 Location:Canada |
i have a 2004, and i had to replace the rad as well. Mechanic said that the radiators on most models in the 2003-2006 range were poor in quality. He replaced it with an OEM Radiator for $350 + labor (150).
Jul 17 2009, 12:46 AM
Post
#7
New Club Member ![]() Group: Regular Member Posts: 4 Joined: 4-October 08 From: Green room Member No.: 80,706 Car Model:None Location:Green room |
On some GX the radiator will develop a leak(slow leak) on the left lower corner of the radiator. It will have a crusty pink flake build up in the area. I recommend getting a factory radiator, because the radiator hose will have a snug fit on the snout using the original hose clamps.
Jul 22 2009, 10:20 AM
Post
#8
New Club Member ![]() Group: Regular Member Posts: 7 Joined: 22-February 09 From: Napa Member No.: 89,049 Car Model:GX470 Location:Napa |
My radiator leaked at 49k miles. I am very glad I purchased an aftermarket extended warranty. It almost paid for itself after the $800 the Lexus dealership charged to do the repair.
Jul 22 2009, 09:43 PM
Post
#9
I think manufacturing defects are very rare, unless anything associated with welding occasionally seen as most notably, failures occur where oil residues are present within radiators if not lexus would have issued a TSB under the comprehensive warranty for such model. My 04 is still kicking perfect( touchwood) I think Premature failure will usually occur due to pitting corrosion although this will have a wide range of causes. Commonly, oxygen pitting, chloride induced pitting and pitting associated with copper plating are found. Pitting usually occurs at areas of natural stress, i.e. convex folds or near welds which are anodic sites in the radiator. Manufacturing defects are rare but where found are commonly associated with welding defects. New radiators fitted to old systems are anodic to the system and are prone to premature failure. Old radiators may eventually fail due to under deposit corrosion associated with sludge deposits, usually magnetite, at the bottom-centre of the panel, which causes pitting corrosion in the absence of any specific fault with the water or system. In most radiators sludge accumulation causes blockage, or inefficiency, long before the radiator leaks.
Lo-Fi Version | Time is now: 21st November 2009 - 03:08 PM |
