Jul 8 2008, 05:21 PM
Post
#16
Advanced Club Member ![]() ![]() ![]() Group: Regular Member Posts: 264 Joined: 23-April 07 From: Moved from LI NY to Anderson SC Aug 07 Member No.: 42,189 Car Model:traded 07 RX400H for 08 GS450H Location:Anderson SC |
Also if you do a lot of hard braking, [racing on the track or long descents down high steep mountain roads] the fluid temp can get very high, the water can boil and turn to steam. When that happens you can lose most if not all of the ability to brake. Hugh? Brake fluid turn to steam? Brake fluid is oil ... so steam |
Jul 9 2008, 05:09 AM
Post
#17
![]() Dedicated Member Group: Gold Member Posts: 744 Joined: 28-April 08 From: Miami Member No.: 70,170 Car Model:'06 IS350 Location:Miami,Fl.,USA |
Hygroscopic does not mean it contains water, it means it can easily absorb moisture. Brake fluid can not contain any moisture what so ever because that is what will degenerate your brake system. Now in racing and repeatedly hard braking when the brake fluid over heats then that miosture will turn to steam if there is any present, if not the brake fluid it self will boil at a much higher temp.
Jul 9 2008, 10:19 AM
Post
#18
Hygroscopic does not mean it contains water, it means it can easily absorb moisture. Brake fluid can not contain any moisture what so ever because that is what will degenerate your brake system. Now in racing and repeatedly hard braking when the brake fluid over heats then that miosture will turn to steam if there is any present, if not the brake fluid it self will boil at a much higher temp. Thank you that waas the point I was trying to make |
Jul 9 2008, 12:15 PM
Post
#19
Your welcome
Jul 24 2008, 05:13 PM
Post
#20
Advanced Club Member ![]() ![]() ![]() Group: Regular Member Posts: 108 Joined: 24-February 06 Member No.: 23,738 Car Model:LS430 Location:Los Angeles, CA |
I've seen brake fluid from the calipers look much worse than fluid further up in the system. One method I've heard about and used is to open the bleed port in the caliper when changing the pads. This allows the old fluid to come out when the pistons are pushed back for the new pads. Then, when I've changed all the pads for that maintenance (both front and rears rarely need to be changed at the same time), I pull some additional fluid through the calipers and top off the system appropriately. I think the key item is that you never want to get contaminated fluid into the anti-lock brake mechanism, it would not be a simple repair if you ever had a fault.
Jul 25 2008, 10:33 AM
Post
#21
High Fiber Member ![]() ![]() ![]() ![]() Group: Regular Member Posts: 644 Joined: 30-October 06 From: Kalispell MT or South OC, CA Member No.: 32,883 Car Model:'06 RX400h AWD Location:MT & CA |
I've seen brake fluid from the calipers look much worse than fluid further up in the system. One method I've heard about and used is to open the bleed port in the caliper when changing the pads. This allows the old fluid to come out when the pistons are pushed back for the new pads. Then, when I've changed all the pads for that maintenance (both front and rears rarely need to be changed at the same time), I pull some additional fluid through the calipers and top off the system appropriately. I think the key item is that you never want to get contaminated fluid into the anti-lock brake mechanism, it would not be a simple repair if you ever had a fault. Ever looked at the front calipers on your hybrid (much less, the rear)? We have over 70K miles on one of our hybrids. There's so much of the stopping power done by regenerative energy recapture, that literally the minimum wear ever takes place. Our front pad? You'd be hard pressed to even guess that they have 4K miles on 'em ... much less the rear pads. You'd really have to be doing tons of crazy-insane breaking to get pads to wear a lot, on a hybrid. In fact, the bigger problem for those who drive extra carefull in hybrids, is rust building up on the rotors. So I hit 'em hard ever so often, to keep the rust off ... just in case. As for fluid change, since the Toyota hybrid specialist confirms 100K miles is do-able. That's when we'll be doing the flush. |
Aug 30 2008, 08:52 PM
Post
#22
New Club Member ![]() Group: Regular Member Posts: 17 Joined: 1-October 07 Member No.: 54,227 Car Model:RX 400h Location:Seattle, WA |
Also if you do a lot of hard braking, [racing on the track or long descents down high steep mountain roads] the fluid temp can get very high, the water can boil and turn to steam. When that happens you can lose most if not all of the ability to brake. Hugh? Brake fluid turn to steam? Brake fluid is oil ... so, no steam What he was saying is, the brake fluid can attract moisture (water) if any is present. So, if the system has managed to attract water, high temperatures can turn the water to steam. Not something you want. This has been a major concern with the newer brake fluids. I'm looking ahead to the 30k service and want to be prepared for any dealer 'games.' What are dealers charging for the brake fluid flush? Might make sense to rent the appropriate tool and do it myself... Fenton House |
Aug 30 2008, 09:37 PM
Post
#23
Club Member ![]() ![]() Group: Regular Member Posts: 94 Joined: 20-April 04 Member No.: 7,915 Car Model:rx400h Location:SO Cal |
Also if you do a lot of hard braking, [racing on the track or long descents down high steep mountain roads] the fluid temp can get very high, the water can boil and turn to steam. When that happens you can lose most if not all of the ability to brake. Hugh? Brake fluid turn to steam? Brake fluid is oil ... so, no steam What he was saying is, the brake fluid can attract moisture (water) if any is present. So, if the system has managed to attract water, high temperatures can turn the water to steam. Not something you want. This has been a major concern with the newer brake fluids. I'm looking ahead to the 30k service and want to be prepared for any dealer 'games.' What are dealers charging for the brake fluid flush? Might make sense to rent the appropriate tool and do it myself... Fenton House All that is needed is a transparent container, a length of tubing, a wrench, spare fluid, and a helper. Devices are available (i.e. tubing with a check valve) to eliminate the need for the helper. It is not at all difficult if you have a little experience working on automobiles. |
Aug 30 2008, 09:56 PM
Post
#24
![]() Guru Member Group: Super Moderator Posts: 1,424 Joined: 16-March 04 Member No.: 6,874 Car Model:2006 RX400h Bamboo Pearl, AWD; 2001 Corvette Coupe, 375 HP 6-sp Location:San Diego, CA |
I do have plenty of experience, but with a painted garage floor, I am wary of doing any more brake fluid flushes. Time is another issue for me now, as I'd rather not spend an afternoon doing it, myself.
But you are correct in that is not difficult as long as you bleed in the correct sequence. Dave |
Aug 31 2008, 09:17 AM
Post
#25
Advanced Club Member ![]() ![]() ![]() Group: Regular Member Posts: 142 Joined: 18-January 07 Member No.: 37,025 Car Model:2005 es 330 Location:San Diego |
I do have plenty of experience, but with a painted garage floor, I am wary of doing any more brake fluid flushes. Time is another issue for me now, as I'd rather not spend an afternoon doing it, myself. But you are correct in that is not difficult as long as you bleed in the correct sequence. Dave I see you are in San Diego. Just had the 30,000 check done on a ES 330 at Bob Baker Toyota on Federal Ave. $230 including a discount coupon for the brake bleed that they had at the shop. |
Aug 31 2008, 12:06 PM
Post
#26
Dedicated Member ![]() ![]() ![]() ![]() Group: Regular Member Posts: 647 Joined: 2-October 06 Member No.: 31,334 Car Model:07 RX400h FWD, 93 Porsche 968 Cabriolet Location:Scottsdale, AZ |
I do have plenty of experience, but with a painted garage floor, I am wary of doing any more brake fluid flushes. Time is another issue for me now, as I'd rather not spend an afternoon doing it, myself. But you are correct in that is not difficult as long as you bleed in the correct sequence. Dave That's an interesting point, Dave. I am considering painting my garage floor, probably with epoxy. Isn't this impervious to brake fluid and other solvents? Tom |
Aug 31 2008, 04:03 PM
Post
#27
Tom,
I believe it is, but you might want to check with the manufacturer to be sure. Brake fluid is very strong (can eat through polyurethane paint, from what I understand) stuff. Unfortunately, when my house was being built, the home-type epoxy floor coating kits were not very common and those companies that would do the whole job were asking an arm and leg for payment. Thus, I went with paint. Someday, though............... Dave |
Sep 1 2008, 12:44 PM
Post
#28
Dave. I know more about DOT3 damaging paint than I wish to remember. I once had a car vandalized with DOT3--apartment neighbors jealous of my brand new car. It dissolved the paint right down to bare metal.
Tom |
Sep 5 2008, 03:45 PM
Post
#29
![]() Advanced Club Member ![]() ![]() ![]() Group: Regular Member Posts: 416 Joined: 2-July 06 From: Los Angeles, CA Member No.: 26,996 Car Model: 2006 RX400h Location:Los Angeles |
I'm being charged $599 for my 30K. service.
Sep 5 2008, 09:16 PM
Post
#30
Dave. I know more about DOT3 damaging paint than I wish to remember. I once had a car vandalized with DOT3--apartment neighbors jealous of my brand new car. It dissolved the paint right down to bare metal. Tom OUCH! QUOTE I'm being charged $599 for my 30K. service. DOUBLE OUCH! |
Lo-Fi Version | Time is now: 21st November 2009 - 08:01 AM |
