Welcome Guest ( Log In | Register )
Reply to this topicStart new topic
> Gx470 Oil Filter Location
PVGXGuy
post May 6 2007, 03:03 PM
Post #1
New Club Member
Group: Regular Member
Car Model:GX470
Recently bought my 1st Lexux, a GX470. Have always been a self-maintainer for oil, brakes, etc. Went into the engine compartment looking for the oil filter today and found it--after a while--but there's a shroud covering it from the bottom that appears to require 6-8 bolts to be removed to gain access to the filter. Am I missing something here or is this maintenance job going to be really time consuming? Any help appreciated
Go to the top of the page
+Quote Post
dvzzz
post May 19 2007, 10:21 PM
Post #2
New Club Member
Group: Members
Car Model:GX470
QUOTE(PVGXGuy @ May 6 2007, 04:03 PM) [snapback]239174[/snapback]
You need to remove 9 bolts and 1 fastener to get access to the filter. I recommend that you remove both plastic cover at the front and then metal one. Then you will see the filter. It is tight to get access to the filter because of the stabilizer bar.
Do not remove the back plate around the drain plug.
+Quote Post
PVGXGuy
post May 21 2007, 05:57 PM
Post #3
New Club Member
Car Model:GX470
QUOTE(dvzzz @ May 19 2007, 11:21 PM) [snapback]241347[/snapback]
thanks much for the help.
+Quote Post
edogcooter
post Jan 12 2008, 04:52 PM
Post #4
New Club Member
Group: Members
Car Model:GX470
do you get to it from the engine or underneath? I can't find the damn thing...a picture would be appreciated as well if anyone has one. thanks...
+Quote Post
aljodoro
post May 30 2009, 10:07 PM
Post #5
New Club Member
Car Model:gx470
I jsut got a gx470 and plan to change the oil myself. I found the filter on the drivers side in the front. Did you find you had to remove the skid plate. How many zerk fittings did you find that needed to be greased. Thanks, Al
+Quote Post
RobLexusGX470
post Jun 8 2009, 08:22 PM
Post #6
New Club Member
Car Model:GX470
QUOTE (edogcooter @ Jan 12 2008, 04:52 PM) *
I find that I can reach it from the top just barely. I grab the filter wrench and slide it in to start it and then I can untwist with my hand. However, it is messy as the oil spills onto the skid plate so you get drops for a few days.
+Quote Post
mann777
post Jun 9 2009, 08:32 AM
Post #7
Advanced Club Member
Car Model:LS400- 1994 / GX470-2004 / LS460 - 2007
In order to have the oil wrench rotate easily once you you get hold of the filter, and in order to that you should have the Front Engine under cover and the Engine Main under cover removed. This would make things easier.
+Quote Post
RSS Lo-Fi Version Time is now: 21st November 2009 - 06:57 AM
