Dec 11 2005, 01:34 PM
Post
#1
Advanced Club Member ![]() ![]() ![]() Group: Regular Member Posts: 353 Joined: 6-December 05 Member No.: 22,026 Car Model:rx330 Location:Pittsburgh, PA |
Well, we finally had a decent snowfall in Pittsburgh and I decided to re-read the owner's manual on the function of the "ECT Snow" button, just to the left of the shifter on my 05 RX. Talk about a lack of information.
Do any of you have good information other than what the manual says? IIRC, it says to get started, push the button. Is it like locking a differential on a 4x4 pickup? How fast can you go with the button pressed and the light on? I am thinking that when using the system, that one should limit the speed to very slow. Any ideas or thoughts on this? Gary |
Dec 11 2005, 01:58 PM
Post
#2
![]() Advanced Club Member ![]() ![]() ![]() Group: Regular Member Posts: 452 Joined: 8-August 04 Member No.: 11,326 Car Model:4Runner Limited/ 08-RX350AWD Silver/Nav/Black Int Location:Anchorage Alaska |
All the button does is start the car in 2nd gear to help take off in slippery conditions--thats it!
You can use it all year if you want and it would be ok, it has nothing to do with DIfferentails. And you can go as fast as your 330 can go! There is no speed limit for it of you have it pressed. |
Dec 11 2005, 03:29 PM
Post
#3
Guru Member ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 2,531 Joined: 14-October 04 From: Lincoln, RI Member No.: 13,420 Car Model:Rx350, LS430, Rx300 Location:Lincoln, RI |
I never noticed a difference.
All i notice is that it takes more pressure on the pedal before the car starts to go. I guess it prevents the "slipping" at first when taking off. |
Dec 11 2005, 04:39 PM
Post
#4
because its starting in 2nd gear:)
Dec 12 2005, 04:40 PM
Post
#5
QUOTE(Booyah @ Dec 11 2005, 03:58 PM) All the button does is start the car in 2nd gear to help take off in slippery conditions--thats it! You can use it all year if you want and it would be ok, it has nothing to do with DIfferentails. And you can go as fast as your 330 can go! There is no speed limit for it of you have it pressed. [right][snapback]169170[/snapback][/right] Great information. Where did you get that? I think that, as great as this car is, the manual leaves a lot to be desired. Thanks Gary |
Dec 12 2005, 05:28 PM
Post
#6
Pretty sure its right in the manual! Ill look in mine tonight
Dec 12 2005, 08:32 PM
Post
#7
Club Member ![]() ![]() Group: Regular Member Posts: 41 Joined: 12-December 05 Member No.: 22,140 Car Model:RX 300 Location:Ohio |
QUOTE(Grumpa72 @ Dec 12 2005, 04:40 PM) QUOTE(Booyah @ Dec 11 2005, 03:58 PM) All the button does is start the car in 2nd gear to help take off in slippery conditions--thats it! You can use it all year if you want and it would be ok, it has nothing to do with DIfferentails. And you can go as fast as your 330 can go! There is no speed limit for it of you have it pressed. [right][snapback]169170[/snapback][/right] Great information. Where did you get that? I think that, as great as this car is, the manual leaves a lot to be desired. Thanks Gary [right][snapback]169351[/snapback][/right] My manual has poor info at the very best as well. Called he dealer and he explained it exactly as mentioned above. Does nothing more than start your Lexus in second gear. Simply helps in the slipping department. Mine is AWD with the rear Limited Slip. I have no issues and have never used the ECT option.. |
Dec 13 2005, 09:20 PM
Post
#8
Advanced Club Member ![]() ![]() ![]() Group: Regular Member Posts: 122 Joined: 28-August 05 Member No.: 20,254 Car Model:'04 RX330 FWD Location:SE US |
Keep in mind that this is a Japanese vehicle with a manual written by a Japanese company. It was probably first written in Japanese and then translated to English. For example the manual says of the SNOW ECT button, "USE THIS MODE WHEN STARTING YOUR VEHICLE IN ICE AND SNOW". Some could misunderstand this to mean actually turning the car on. A better translation would be, "USE THIS MODE WHEN ACCELERATING YOUR VEHICLE IN ICE AND SNOW FROM A STAND STILL"
For more examples of bad translation check out Engrish.com |
Dec 14 2005, 11:15 AM
Post
#9
New Club Member ![]() Group: Members Posts: 4 Joined: 6-December 05 Member No.: 22,029 Car Model:GX330 Location:Dayton, Ohio |
QUOTE(Grumpa72 @ Dec 11 2005, 01:34 PM) Well, we finally had a decent snowfall in Pittsburgh and I decided to re-read the owner's manual on the function of the "ECT Snow" button, just to the left of the shifter on my 05 RX. Talk about a lack of information. Do any of you have good information other than what the manual says? IIRC, it says to get started, push the button. Is it like locking a differential on a 4x4 pickup? How fast can you go with the button pressed and the light on? I am thinking that when using the system, that one should limit the speed to very slow. Any ideas or thoughts on this? Gary [right][snapback]169165[/snapback][/right] I was told by the dealer that this function started the car off in second gear rather than first to prevent tire spinning and easier traction in snow. Dan |
Dec 14 2005, 11:17 AM
Post
#10
![]() Guru Member Group: Gold Member Posts: 9,363 Joined: 11-June 03 From: There Member No.: 1,634 Car Model:98 GS300, BLK/BLK Location:Here |
QUOTE(OH330 @ Dec 14 2005, 05:15 PM) QUOTE(Grumpa72 @ Dec 11 2005, 01:34 PM) Well, we finally had a decent snowfall in Pittsburgh and I decided to re-read the owner's manual on the function of the "ECT Snow" button, just to the left of the shifter on my 05 RX. Talk about a lack of information. Do any of you have good information other than what the manual says? IIRC, it says to get started, push the button. Is it like locking a differential on a 4x4 pickup? How fast can you go with the button pressed and the light on? I am thinking that when using the system, that one should limit the speed to very slow. Any ideas or thoughts on this? Gary [right][snapback]169165[/snapback][/right] I was told by the dealer that this function started the car off in second gear rather than first to prevent tire spinning and easier traction in snow. Dan [right][snapback]169719[/snapback][/right] It not only starts in 2nd gear the acceleration is also retarded. Works Great on my GS here in Mn. winters. |
Jan 3 2006, 12:48 AM
Post
#11
![]() Guru Member ![]() ![]() ![]() ![]() ![]() Group: Regular Member Posts: 2,321 Joined: 6-June 05 From: San Francisco Member No.: 18,355 Car Model:'04 Rx330, '02 Is300 Location:San Francisco |
I dont notice anything on my rx330, but today i tried it on my is300 and big mistake...to do it while on the freeway. It basically shifted down and the rpm meter went way up...kinda like limiting my speed
Jan 3 2006, 11:33 AM
Post
#12
QUOTE(Rx330driver @ Jan 2 2006, 09:48 PM) [snapback]172790[/snapback] I dont notice anything on my rx330, but today i tried it on my is300 and big mistake...to do it while on the freeway. It basically shifted down and the rpm meter went way up...kinda like limiting my speed YOU are talking about the OD (overdrive) button and thats correct on what happened!~ We are talking about the ECT SNOW button--totally differant thing |
Jan 3 2006, 07:16 PM
Post
#13
QUOTE(Booyah @ Jan 3 2006, 09:33 AM) [snapback]172848[/snapback] QUOTE(Rx330driver @ Jan 2 2006, 09:48 PM) [snapback]172790[/snapback] I dont notice anything on my rx330, but today i tried it on my is300 and big mistake...to do it while on the freeway. It basically shifted down and the rpm meter went way up...kinda like limiting my speed YOU are talking about the OD (overdrive) button and thats correct on what happened!~ We are talking about the ECT SNOW button--totally differant thing :chairshot: oh common, im not that stupid...how can you misunderstand the OD button for the SNOW button. There isnt even and OD button on the IS. im sure its the SNOW button...on top of the POWER button next to the shifter This post has been edited by Rx330driver: Jan 3 2006, 07:24 PM |
Jan 4 2006, 12:05 AM
Post
#14
you sure you didnt hit the rear defogger button:)
Jan 4 2006, 12:28 AM
Post
#15
errrr
Lo-Fi Version | Time is now: 21st November 2009 - 06:36 AM |
