Programming New Transponder Key For 2001 Ls430
Marconi
I have read some talking about the 98-2000 key programming, but most of the poeple said it is the same technoligy used , so it would be the same way.
read the atrical attached
and I remember found the same talk in one website , but cant' recall it now.
let us know if it worked with you or not.
98__Key_programming_instructions.doc
I just did my 2002 LS430 2 days ago; I got a brand new transponder key and instructions for about $150, and then I paid $12.50 to have the key cut which you will need to do before programming.
Instructions:
- driver's door closed, key removed from ignition switch
- obtain 1 already programmed black key
- insert already programmed black key into ignition
- within 35 seconds of previous step switch ignition ON and OFF 5 times
- open and close driver's door 6 times
- remove black key from ignition
- within 10 seconds of previous step insert new key to be programmed into ignition switch
- after 1 minute immobilizer lamp (to left of steering wheel column) will extinguish
- remove key
- DONE
NOTE: a maximum of 5 black keys and 3 gray keys can be programmed.
If you guys need the instructions for programming the transponder (remote trunk and door lock) let me know.
  • Like 1
I Tought I had done the above procedures in the correct sequence, but to no avail. I don't guess its necessary to start the engine when the ignition switch is turned to 'on'. I guess I'll just keep trying. Thanks for your help.
  • 2 years later...
Yeah, I just got a 2003 LS430. Got the key to start the engine, but need help to program lock/unlock/trunk.
Thanks.
Instructions:
- remove key
- DONE
You might call around and ask if your dealer will do it. I ordered mine pre-cut from Sewell and spent a couple days trying to figure out how to program it. Eventually I just gave up and went to Lexus of Santa Monica where they did it for free in about 10 minutes.
Thanks.
Instructions:
- remove key
- DONE
This might be useful:
http://www.toy-lex.com/
Browse the website they have key programming instructions for about every lexus.
Thanks.
Instructions:
- remove key
- DONE
  • 2 months later...
I tried these ones and after 4 or 5 tries I've given up. I have a message in to my dealer to find out if they'll do it for free.
Thanks.
Instructions:
- remove key
- DONE
  • 2 months later...
  • 4 weeks later...
Does anyone have prgramming instructions to program a valet key for a 2001 Lexus LS430. Key turns over car but doesnt start it.
I purchased a valet Key from Sewell Lexus Parts online.
Thanks!
Will
Thanks.
Instructions:
- remove key
- DONE
  • 1 year later...
Instructions:
- remove key
- DONE
Hello Jason,
Do you still have the complete instructions for programming a new key transponder for staring the car and trunk and door, I have a LS 2003 black on black but lost the other key, i do have the master key that I'm using, I bought the key from Sewell lexus, thanks, in advance . roger
Instructions:
- remove key
- DONE
Hello Jason,
Do you still have the instructions to program keys for starting to opening doors /trunk? Just bought new key from sewell lexus, i've lost my other key and only have the masterkey, thanks, in advance, happy holidays, roger
