Feb 7 2005, 06:57 PM
Post
#1
New Club Member ![]() Group: Members Posts: 7 Joined: 16-November 04 Member No.: 14,079 Car Model:GX470 Location:Philadelphia |
I have a 2004 GX470 and want to install a 2" receiver for connecting a towing hitch for trailering a boat. The dealer has informed me they cannot install a factory mount. (Lexus Nat'l does not allow this as a dealer installed option - only port or factory) Does anyone know anything about this? If so, what have you done?
Thanks. |
Feb 8 2005, 12:22 PM
Post
#2
Club Member ![]() ![]() Group: Regular Member Posts: 64 Joined: 24-March 04 Member No.: 7,111 Car Model:2004 GX470 w/ kdss Location:So. California |
QUOTE(RobGX470 @ Feb 7 2005, 06:57 PM) I have a 2004 GX470 and want to install a 2" receiver for connecting a towing hitch for trailering a boat. The dealer has informed me they cannot install a factory mount. (Lexus Nat'l does not allow this as a dealer installed option - only port or factory) Does anyone know anything about this? If so, what have you done? Thanks. [right][snapback]109753[/snapback][/right] To this regard, Lexus indeed really sucks @$$. Most manufactures seem to allow some post modification with factory parts. I have a 2004 GX, with KDSS, in which the tow hitch was NOT an option. The dealership will not install it with the manufacture's components, nor will they sell them to you (they want to match the sale of the parts to your VIN). You have to install a 3rd party hitch system. You can look around, but there is a company called Draw-Tite that makes a bolt-in 2" reciever rated for 5000lbs. ( http://www.draw-tite.com ). The model number for the GX is #75155. I think the Ball and Hitch assembly will fall just under your rear bumber, so you do not have to remove the cover plate from the bumper itself. I have not had this item installed, but intend to. As yet I cannot comment on the whole package appearance. Draw-Tite does state that their product bolts into the existing holes and there is NO further drilling or modification. After that, all you need is your wiring loop to be located. There is a thread on this site which concerns that very topic: http://us.lexusownersclub.com/forums/index...12255&hl=wiring From what I do understand, it is actually a better hitch than what Lexus offers anyway. Good Luck ... I will be joining you in the near future for that same addition. |
Feb 8 2005, 04:00 PM
Post
#3
Club Member ![]() ![]() Group: Regular Member Posts: 64 Joined: 6-August 04 Member No.: 11,292 Car Model:'04 GX470 Location:Texas |
My 2004 GX with KDSS did not have the factory hitch on when I saw it on the lot. In the deal I requested the hitch be put on. When I recieved the GX the hitch was on and everything looked great. I later learned that they had taken my GX to a third party vendor to have it installed. I was going to complain, but the hitch looks just like the factory 6500 rated hitch. It was added at no cost to me. So in my case, the dealer had the hitch added.
Feb 10 2005, 11:19 AM
Post
#4
Thanks. My GX does not have KDSS and the dealer still can't get a factory hitch. Lexus Nat'l won't let the dealer install a hitch mount, only the factory or port. Seems assinine Lexus would not provide for this, given the car is designed to tow! Why buy a V8 SUV if you can't tow with it.
My dealer has been helpful and is pointing me in the direction of an aftermarket hitch - I think it was the drawtite one, but I am not 100% sure. I will let you know how it goes once I get it installed. |
Feb 10 2005, 05:12 PM
Post
#5
New Club Member ![]() Group: Regular Member Posts: 17 Joined: 19-December 04 Member No.: 14,720 Car Model:2005 GX470 Location:colorado |
MY GX will be here in 3 weeks and I need the hitch also. The Lexus dealer said I could not buy the factroy one. I wonder if the hitch that they put on the V-8 Toyota 4 runner is the same as the Lexus hitch.
Feb 10 2005, 06:17 PM
Post
#6
New Club Member ![]() Group: Members Posts: 4 Joined: 21-December 04 Member No.: 14,761 Car Model:GX 470 Location:Jacksonville FL |
QUOTE(RAM MAN @ Feb 10 2005, 06:12 PM) MY GX will be here in 3 weeks and I need the hitch also. The Lexus dealer said I could not buy the factroy one. I wonder if the hitch that they put on the V-8 Toyota 4 runner is the same as the Lexus hitch. [right][snapback]110415[/snapback][/right] Just go to U-Haul and get Part Number 78445 (Class 3 Hitch). 8 Bolts later (the nuts are already welded in to the frame of the GX 470). The Truck is already prewired for the tail lights, etc., so nothing to do there. Cost for 78455 was $179.95 -- Lexus wanted lots more. U-Haul will install it for about $50 more but if you can change a tire you can DIY. Borrow a Torque wrench to get the correct torque on the bolts 65 and 17 pds depending on the size of the bolts. |
Feb 10 2005, 07:51 PM
Post
#7
QUOTE(Robert W Wood Jr @ Feb 10 2005, 05:17 PM) QUOTE(RAM MAN @ Feb 10 2005, 06:12 PM) MY GX will be here in 3 weeks and I need the hitch also. The Lexus dealer said I could not buy the factroy one. I wonder if the hitch that they put on the V-8 Toyota 4 runner is the same as the Lexus hitch. [right][snapback]110415[/snapback][/right] Just go to U-Haul and get Part Number 78445 (Class 3 Hitch). 8 Bolts later (the nuts are already welded in to the frame of the GX 470). The Truck is already prewired for the tail lights, etc., so nothing to do there. Cost for 78455 was $179.95 -- Lexus wanted lots more. U-Haul will install it for about $50 more but if you can change a tire you can DIY. Borrow a Torque wrench to get the correct torque on the bolts 65 and 17 pds depending on the size of the bolts. [right][snapback]110428[/snapback][/right] I have looked at the Draw Tite and U Haul. They dont have as high of a weight rating as the Lexus hitch. Only 3500 LBS Weight-Carrying Capacity |
Feb 11 2005, 05:34 AM
Post
#8
QUOTE(RAM MAN @ Feb 10 2005, 08:51 PM) QUOTE(Robert W Wood Jr @ Feb 10 2005, 05:17 PM) QUOTE(RAM MAN @ Feb 10 2005, 06:12 PM) MY GX will be here in 3 weeks and I need the hitch also. The Lexus dealer said I could not buy the factroy one. I wonder if the hitch that they put on the V-8 Toyota 4 runner is the same as the Lexus hitch. [right][snapback]110415[/snapback][/right] Just go to U-Haul and get Part Number 78445 (Class 3 Hitch). 8 Bolts later (the nuts are already welded in to the frame of the GX 470). The Truck is already prewired for the tail lights, etc., so nothing to do there. Cost for 78455 was $179.95 -- Lexus wanted lots more. U-Haul will install it for about $50 more but if you can change a tire you can DIY. Borrow a Torque wrench to get the correct torque on the bolts 65 and 17 pds depending on the size of the bolts. [right][snapback]110428[/snapback][/right] I have looked at the Draw Tite and U Haul. They dont have as high of a weight rating as the Lexus hitch. Only 3500 LBS Weight-Carrying Capacity [right][snapback]110445[/snapback][/right] The one I purchased (see above) is rated at 5000/500 and 5500/550 if you add anti-sway bars. |
Feb 18 2005, 12:34 AM
Post
#9
New Club Member ![]() Group: Members Posts: 1 Joined: 18-February 05 Member No.: 16,004 Car Model:GX470 Location:CA |
QUOTE(RobGX470 @ Feb 7 2005, 04:57 PM) I have a 2004 GX470 and want to install a 2" receiver for connecting a towing hitch for trailering a boat. The dealer has informed me they cannot install a factory mount. (Lexus Nat'l does not allow this as a dealer installed option - only port or factory) Does anyone know anything about this? If so, what have you done? Thanks. [right][snapback]109753[/snapback][/right] I ran into the same problem as you. I was able to get a factory tow hitch by doing a bit of complaining to Lexus Customer Service. It took a couple of weeks of phone calls and an eventual request to lexus to buy back my GX so that I can buy something that can actually tow a boat/trailer. Eventually they did get an approval from the a regional manager to ship a tow hitch to my dealer for installation. |
Mar 11 2005, 08:41 PM
Post
#10
Today I installed the OEM Lexus hitch that my
Mar 15 2005, 07:54 PM
Post
#11
New Club Member ![]() Group: Members Posts: 9 Joined: 25-November 04 Member No.: 14,231 Car Model:GX 470 Location:New Jersey |
I got the hitch. How did you get the factory plastic plate off?
QUOTE(RAM MAN @ Mar 11 2005, 10:41 PM) Today I installed the OEM Lexus hitch that my
[right][snapback]116382[/snapback][/right] |
Mar 16 2005, 07:26 AM
Post
#12
QUOTE(whazzup @ Mar 15 2005, 06:54 PM) I got the hitch. How did you get the factory plastic plate off? I don't know what plastic plate you are referring to. QUOTE(RAM MAN @ Mar 11 2005, 10:41 PM) Today I installed the OEM Lexus hitch that my [right][snapback]116382[/snapback][/right] [right][snapback]117207[/snapback][/right] |
Mar 16 2005, 05:35 PM
Post
#13
The plastic cover plate that you replace after the hitch is installed
Thanks QUOTE(RAM MAN @ Mar 16 2005, 09:26 AM) QUOTE(whazzup @ Mar 15 2005, 06:54 PM) I got the hitch. How did you get the factory plastic plate off? I don't know what plastic plate you are referring to. QUOTE(RAM MAN @ Mar 11 2005, 10:41 PM) Today I installed the OEM Lexus hitch that my [right][snapback]116382[/snapback][/right] [right][snapback]117207[/snapback][/right] [right][snapback]117280[/snapback][/right] |
Mar 16 2005, 05:42 PM
Post
#14
Mine is an 05' I didn't have to remove any plastic cover plate.
QUOTE(whazzup @ Mar 16 2005, 04:35 PM) The plastic cover plate that you replace after the hitch is installed Thanks QUOTE(RAM MAN @ Mar 16 2005, 09:26 AM) QUOTE(whazzup @ Mar 15 2005, 06:54 PM) I got the hitch. How did you get the factory plastic plate off? I don't know what plastic plate you are referring to. QUOTE(RAM MAN @ Mar 11 2005, 10:41 PM) Today I installed the OEM Lexus hitch that my [right][snapback]116382[/snapback][/right] [right][snapback]117207[/snapback][/right] [right][snapback]117280[/snapback][/right] [right][snapback]117385[/snapback][/right] |
Mar 17 2005, 01:03 PM
Post
#15
Ok, I got a pre-owned (used) 5000lb factory hitch with all the requisite hardware in the mail today.
Lo-Fi Version | Time is now: 9th February 2010 - 04:57 AM |
