All Activity
- Today
filmlaw joined the community
Mark Levinson sound system
filmlaw posted a topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
I am really interested in great car audio. Does anyone have any thoughts on how to set the treble, bass and midrange as well as how to balance the speakers to get the best sound from the driver's seat? - Yesterday
on.level joined the community
RX400h started following Unplugged Battery And Now It Wont Start , Used Lexus 2004 GX and Shifter interlock 2023 NX350
RX400h replied to tak06's topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
What are the Possible Causes of the DTC P1127 Lexus? NOTE: The causes shown may not be a complete list of all potential problems, and it is possible that there may be other causes. Faulty Electronic Throttle Control System (ETCS) Actuator Electronic Throttle Control System (ETCS) Actuator harness is open or shorted Electronic Throttle Control System (ETCS) Actuator circuit poor electrical connection Read more: https://www.autocodes.com/p1127_lexus.html It may be that locating the specific cause is not exactly simple for the doityourselfer.
Daniel laporte joined the community
tak06 replied to tak06's topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
The brake lights work with light pressure, it's the excessive brake pressure in my opinion, perhaps others may not see it as being excessive but I'm used to the old mechanical linkage shifters and not the computerized shift by wire in the new NX350, perhaps it's normal but annoying non the less. -
Report to NHTSA as a safety and security concern. Digital key is not the answer - just more revenue/profit for Lexus ar our expense.
TonyMatinez joined the community
My neighbor is selling his 2004 Gx for 3K. It has 265k miles on it. He has not replaced the timing belt, water pump. Only done simple oil changes. Do you think its worth buying it for 3K?
Mike Black started following Shifter interlock 2023 NX350
Mike Black replied to tak06's topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
Sounds like might be a brake light switch that needs adjusting. Do you brake lights also wait until you press hard to come on? -
chi_soul joined the community
How did you fix your p1127 code issue? I'm having this problem now 😕
hcfmax joined the community
tak06 started following Shifter interlock 2023 NX350
tak06 posted a topic in Lexus NX200 / NX300 / NX350 / NX450 / NXh+ Club
Hi, Just bought a '23 NX350 and the shifting into Reverse or Drive has me wondering if I made a wise purchase, does anyone know why one has to step on the brakes so hard to shift into R or D or is there an option on the infotainment display to lessen the brake pressure to release the shifter interlock? Thanks much for any info on this "issue" -
Emanueal Thomas joined the community
samhd joined the community
vandine started following Digital Key & No Second key fob
Since Lexus has made it's customer service form so cumbersome, I have reported the key fob issue to NHTSA. On the Lexus app, the 2nd Key Program Campaign is not even listed (23LJ01). The dealership cannot provide a clear answer on when this will be fixed. For my wife and me, both 70 years young (I am a disabled Army veteran), this is a potential safety and security concern.
Woofwoof joined the community
Antenna Mast Replacement On 2004 Sc430
Woofwoof replied to jpwonderdog's topic in 01 - 10 Lexus SC430
Works like a charm is right. THANK YOU. - Last week
LDThayer joined the community
NX350AW started following Need help 2021 NX350AWD
Hi I am new to this group i own two Lexus 2014 RX350 and recently purchased 2021 NX350AWD and having problem with my 2021 NX350 rearview camera try to get the problem solve with Lexus in past 4 months and still have no clear answer from Lexus if they are going to fix it. Rearview camera is defected not functioning when put on reverse and screen is blank which is part of Lexus safety future when backup i don't know where to turn after four months try to get it fix but Lexus keep telling that camera part 67B0F6021 Camera Assy is in back order and every time i call they keep saying that still backorder but continue promising new ETA of the camera, if anyone can direct me to better way to get Lexus attention and looking to my issued i greatly appreciate the reply and input.
Seanamus started following 02 ES300 constant revving after starting
Seanamus replied to Seanamus's topic in 92 - 06 Lexus ES250/300/330
Thank you RX. I'll keep yiu posted. -
RX400h started following Shift Solenoid and Downshift Clunk
I found this information by running a Bing CoPilot search, given your information:
It's not a transmission problem that is causing this to happen. I researched this issue and figured out what the issue was. The problem is the E.C.M.. There was an extended warranty on this part because of this known Lexus issue (10 years after the factory). My car was older, so I had my E.C.M. repaired. I had it removed and then sent to a shop in TX. After all my research, I found this company to be most reputable, and they did a great job. There may be a company close to you that can do this. If not, message me and I'll give you the info on the company I used.
My Lexus rx300 is immaculate only done 47000,full service history ,showroom condition inside and out ,been unused for 15 years due too illness,car used once a week for local shopping it’s mint condition,still new too look at,2002 first registered,timing belt done by Lexus only about 1000 miles ago,because of cars age,brake pads are renewed,good for 150.000 miles,would swop for Bentley,you won’t buy a better car then mine,
i have exactly the same issue, took it to the transmission shop and they coulden't fix it
I have a 96’ Ls400 with 269k miles, the car is throwing out code for Transmission shift solenoid E, does anyone have any part numbers, or any tutorials online on how to change it, i know the general process just have no idea what it looks like or where to buy it. any advice would be greatly appreciated!
GS350 F SPORT BRAKES
Creighton replied to IMMYUSEF's topic in 2013 - Present Lexus GS350 / GS350 F / GS540h
I have a 2014 gs350 fsport, rwd & am replacing all 4 pads & rotors & was looking for a recommendation. I've done tons of research on Amazon, eBay, forums, etc. im getting mildly overwhelmed w all the did things I've read. -
RX400h replied to Seanamus's topic in 92 - 06 Lexus ES250/300/330
Topics
